system
1
(imported topic written by PSanesi)
A customer, where TEM it’s going to be implemented, has SiteMinder SSO solution in place.
Do you know if it’s possible to integrate the TEM Console logon process in this SSO solution or other solutions?
Is there any best practices about how to do this?
Thanks for any suggestion
Paolo
(imported comment written by liuhoting)
My impression is that this would be a professional services sort of engagement.
system
3
(imported comment written by PSanesi)
Probably yes. My question is about the feasibility of the integration.
Is it SSO integration supported by TEM Console logon process?
I didn’t find anything specific in TEM documentation.
Regards, Paolo
