(imported topic written by Bhushan Chirmade)
Hello,
I am facing very strange issue. I have installed TEM 8.2.1093.0 evaluation version using express mode. Everything worked perfect initially including console login. Then I installed platform API 8.2.1093.0. Created a simple vbscript to create a test fixlet:
Dim username, password, dsn, privatekey
username = “EvaluationUser”
password = “ABC”
dsn = “bes_bfenterprise”
Set sk = CreateObject(“BESAPI.SigningKeys”)
sk.SetDefaultDSN(dsn)
'WScript.Echo sk.DiagnosticMessage
Set fc = CreateObject(“BESAPI.FixletCreator”)
fc.SetFixletType(“Fixlet”)
fc.SetName(“TestFixlet-BC1”)
fc.SetMessage(“This fixlet is relevant always”)
fc.SetRelevance(“true”)
fc.SetActionDescription(“Click here to deploy this action”)
fc.SetActionScript(“true”)
fc.SetActionTypeMIME(“application/x-fixlet-windows-shell”)
fc.SetCategory(“Miscellaneous”)
fc.SetDownloadSize(“0”)
Wscript.echo “Before propagation”
fc.DoPropagation username,password
Wscript.echo “After propagation”
If fc.fixletID = 0 Then
WScript.Echo "Error: " & fc.DiagnosticMessage
End If
When I ran this code I got following error message:
A database query unexpectedly returned too many results.
I was logged into console at this time. Once I closed my console I am not able to login anymore. I am continuously getting following error messages into filldb.log:
Thu, 29 Dec 2011 18:28:45 -0500 - 2484 - LicenseUpdater error: A database query unexpectedly returned too many results.
Thu, 29 Dec 2011 18:28:49 -0500 - 2480 - A database query unexpectedly returned too many results.
Thu, 29 Dec 2011 18:28:49 -0500 - 2480 - Disconnecting from database; will reconnect in 10 seconds.
Not sure what went wrong. I faced this issue 2 times. Please help to resolve this issue.
Regards,
Bhushan
