TEM 8.1.551 - Right Click Tools Error
Ping IP(s) errors out with:
‘\servernamegoeshere\c$\BESInstallers\Console’
CMD.EXE was started with the above path as the current directory.
UNC paths are not supported. Defaulting to Windows directory.
‘iteratecmd.bat’ is not recognized as an internal or external command,
operable program or batch file.
Trace Route completes but with the following warning:
The ShellCommandRelevance registry setting has not changed, so I’m guessing it is something in the console code?
Ok, not sure WHY this would fix it, but it did.
Cleared console cache and now we are ok.
