system
1
Hi Experts,
I am getting System Error 35 : network path not found while deploying TEM clients through remote deployment.
Also found that the error is due to Admin$ not Available in end points.
Any clues to deploy the TEM clients remotely apart from admin$?
I need to deploy more than 10,000 Endpoint machines.
Any help is really appreciable.
system
2
Is the C$ share available? I would expect since the Admin$ is not, that the C$ is also disabled.
If these are disabled, then it is going to be fairly interesting to deploy ![:slight_smile: :slight_smile:](https://forum.bigfix.com/images/emoji/twitter/slight_smile.png?v=5)
Other methods
Other in-house deployment tools
Active directory
Login scripts - although with this, the users will need admin access
If you have the C$ share and you have admin access to all systems, you could write something to copy the files and remote execute (psexec).
You could also see about getting the Admin$ share activated if that is possible, but I know some companies do not like that.
Martin Carnegie
Gulf Breeze Software Partners
http://www.gulfsoft.com
