(imported topic written by dpalzere91)
The server from which we run BigFix is running low on hard drive space. Is it possible to move the downloads to another directory not on the System Drive? Are the other files that can be moved? Thank you.
(imported comment written by sgreenwall91)
If you are staying on the same server you should be able to follow these steps:
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=387
If you want to change the server that BES is installed on, use these steps:
