Can someone see the below image and help me on this issue.
Let me know, if you need any details…
SUA on RHEL 6.5
Edit: removed image for some security reasons!
SUA on RHEL 6.5
Bump, Can some big guys get involved plz…
I’ve never tried to install SUA, but does it work if the missing packages are installed? If not, you should probably open a support issue.
Hi!
Pls run:
rpm -qa | grep ksh
If you notice pdksh please uninstall it and use the original ksh package from the RH installation image.
Regards
i owe you a beer, that fixed the problem.
Thank you so much \m/
Cheers !!!
I hope the command provided by @krk will works.
