Strange Registry Setting
(imported topic written by bigfix186591)
Hello
I am trying to set a client setting using a task that I created. The registry setting is not appearing correctly it contains %% symbols.
HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\EnterpriseClient\Settings\Client_BESClient_Register_Affiliation_SeekList%22%3d%22%7bsetting %22Location by IP Range%7d%22 of client%
Can you show us the Action Script setting command you are using?
%22 is a percent-encoded double-quote character – 7D and 7B are {} and 3D is =.
I’m guessing you are doing some relevance substitution in your setting command?
