(imported topic written by murtasma91)
Working with the follwing BigFix KB
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=482
Currently in our deployment our BigFix Database and Web Reports Database are located on a SQL cluster on another domain with no trust between the domain where the server resides and the SQL cluster lives. We are using SQL Authentication to access the database.
Based on what the KB article states
“Note: The Windows user account used to execute the Scheduled Task must have access to the BigFix Database”
It does not appear like this tool will be compatible with our configuration. When I attempt to use the exe I get the following errors.
Will this tool work for us or will we have to have our operators manually update the historical data when they need to view reports?
15:12:24 - Problem querying Web Reports (attempt 1 of 10)
15:12:24 - Problem querying Web Reports (attempt 2 of 10)
15:12:24 - Problem querying Web Reports (attempt 3 of 10)
15:12:24 - Problem querying Web Reports (attempt 4 of 10)
15:12:24 - Problem querying Web Reports (attempt 5 of 10)
15:12:24 - Problem querying Web Reports (attempt 6 of 10)
15:12:24 - Problem querying Web Reports (attempt 7 of 10)
15:12:24 - Problem querying Web Reports (attempt 8 of 10)
15:12:24 - Problem querying Web Reports (attempt 9 of 10)
15:12:24 - Problem querying Web Reports (attempt 10 of 10)
15:12:24 - Could not get retrieve an answer for expression: current date as str
ing
—Sep 23, 2009 :: Connecting to —
DBI connect(‘bes_bfenterprise’,’’,…) failed:
Microsoft
[ODBC SQL Server Drive
r]
SQL Server
Login failed for user ‘’. The user is not associated with a truste
d SQL Server connection. (SQL-28000)(DBD: db_login/SQLConnect err=-1) at StoreHi
storicalPMResults.pl line 590
Couldn’t connect to database:
Microsoft
ODBC SQL Server Driver
SQL Server
Log
in failed for user ‘’. The user is not associated with a trusted SQL Server conn
ection. (SQL-28000)(DBD: db_login/SQLConnect err=-1) at StoreHistoricalPMResults
.pl line 590.
