(imported comment written by naveedm)
Hi Adam,
Could you try reattaching the screen shot? I don’t think it came through.
The “BES Server Plugin Service" runs the “Store Power Data Utility" once per day using the web reports username, password, and URL stored in the registry.
When data is not being stored, it’s often because the username, password, or URL wasn’t entered into the registry correctly, but it sounds like this may not be the cause of the issue you’re experiencing.
The log for the “Store Power Data Utility" is located in \BigFix Enterprise\BES Server\Applications\BESAggregator.
The log for the “BES Server Plugin Service" (MFS.exe) is located in \BigFix Enterprise\BES Server\Applications\Logs.
Can you let us know what the logs show?
Successful entries for both logs are below.
Cheers,
Naveed
BESAggregatePowerData.log
Thu Oct 14 08:04:17 2010
INFO
Running BESAggregatePowerData.exe version 0.7.35
INFO
Connecting to webreports at http://nmakhani/webreports
INFO
Connecting to database on bes_bfenterprise.
INFO
No aggregation policies were found.
INFO
Creating group for all computers
INFO
Found 1 groupings for manual grouping policy “All Computers”
INFO
Generating power data for group “All Computers”
Thu Oct 14 08:04:18 2010
INFO
Adding today’s data to power history…
Thu Oct 14 08:04:20 2010
INFO
Utility Successfully Completed!
MFS.log
Thu, 14 Oct 2010 08:04:16 -0700
Task ‘BESAggregatePowerData’ run by command: “C:\Program Files (x86)\BigFix Enterprise\BES Server\Applications\BESAggregator\BESAggregatePowerData.exe” -url http://nmakhani/webreports -u naveed -p ***** -odbc bes_bfenterprise -dbuser -dbpass
