Stop Running Script pop-up frequently pops up
Is there a BigFix setting that prevents the console from frequently displaying “Stop Running Script” pop-up?
I normally see this when I use the following wizard/dashboards:
Synchronize Checklist Dashboard (SCM)
Image Library Dashboard (OSD)
File Pre-cache Wizard
Hello,
Could you please indicate the details of the OSD scenario?
A screenshot would be appreciated
There’s not a BigFix setting for this, but there is something in Internet Explorer or the Internet Control Panel that can be used to allow scripts to run longer before displaying the pop-up. Internally, the Console is using an IE Active-X control to do much of the HTML rendering and JavaScript in these dashboards.
I’ll try to find the relevant settings later but wanted to chime in now in case that helps point you in a direction.
Did we ever get to the bottom of this? I’m trying to synchronize a load of Custom Checks, and it is extraordinarily irritating having to click “No” every few minutes.
I believe the setting is for MaxScriptStatements, this is what I used to get rid of the pop-ups for myself:
reg add “HKCU\Software\Microsoft\Internet Explorer\Styles” /f
reg add “HKCU\Software\Microsoft\Internet Explorer\Styles” /v “MaxScriptStatements” /t REG_DWORD /d 0xFFFFFFFF /f
This is documented here also:
