Hi all,
I created an analysis to retrieve the SQL Server patch level, and it’s working as expected, I can see the column populated on the computer objects. I was also able to include this column in a report listing all SQL Servers.
However, when I run an action using a baseline and generate a report to view the status, I’m unable to include the patch level column in the action report.
Do you know if there’s a way to add that column to the baseline action report?
