Query to monitor SQL Jobs due to we are handling many BigFix sql jobs customized.
I need to gather the following records: Agent SQL Job Name, Status, Enabled (yes or not), Scheduled, Description etc etc etc! and I have all that info BUT I am still unabled to gather the email default notification of each job! …probably this is a question for MS…but I am posting here just in case someone else need this info.
—new we need to add the email notification
SELECT [JobName] = [jobs].[name]
,[Category] = [categories].[name]
,[Owner] = SUSER_SNAME([jobs].[owner_sid])
,[Enabled] = CASE [jobs].[enabled] WHEN 1 THEN ‘Yes’ ELSE ‘No’ END
,[Scheduled] = CASE [schedule].[enabled] WHEN 1 THEN ‘Yes’ ELSE ‘No’ END
,[Description] = [jobs].[description]
,[Occurs] =
CASE [schedule].[freq_type]
WHEN 1 THEN 'Once’
WHEN 4 THEN 'Daily’
WHEN 8 THEN 'Weekly’
WHEN 16 THEN 'Monthly’
WHEN 32 THEN 'Monthly relative’
WHEN 64 THEN 'When SQL Server Agent starts’
WHEN 128 THEN 'Start whenever the CPU(s) become idle’
ELSE ''
END
,[Occurs_detail] =
WHEN 1 THEN 'O’
WHEN 4 THEN 'Every ’ + CONVERT(VARCHAR, [schedule].[freq_interval]) + ’ day(s)'
WHEN 8 THEN 'Every ’ + CONVERT(VARCHAR, [schedule].[freq_recurrence_factor]) + ’ weeks(s) on ’ +
LEFT(
CASE WHEN [schedule].[freq_interval] & 1 = 1 THEN 'Sunday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 2 = 2 THEN 'Monday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 4 = 4 THEN 'Tuesday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 8 = 8 THEN 'Wednesday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 16 = 16 THEN 'Thursday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 32 = 32 THEN 'Friday, ’ ELSE ‘’ END +
CASE WHEN [schedule].[freq_interval] & 64 = 64 THEN 'Saturday, ’ ELSE ‘’ END ,
LEN(
) - 1
WHEN 16 THEN 'Day ’ + CONVERT(VARCHAR, [schedule].[freq_interval]) + ’ of every ’ + CONVERT(VARCHAR, [schedule].[freq_recurrence_factor]) + ’ month(s)'
WHEN 32 THEN 'The ’ +
CASE [schedule].[freq_relative_interval]
WHEN 1 THEN 'First’
WHEN 2 THEN 'Second’
WHEN 4 THEN 'Third’
WHEN 8 THEN 'Fourth’
WHEN 16 THEN 'Last’
END +
CASE [schedule].[freq_interval]
WHEN 1 THEN ’ Sunday’
WHEN 2 THEN ’ Monday’
WHEN 3 THEN ’ Tuesday’
WHEN 4 THEN ’ Wednesday’
WHEN 5 THEN ’ Thursday’
WHEN 6 THEN ’ Friday’
WHEN 7 THEN ’ Saturday’
WHEN 8 THEN ’ Day’
WHEN 9 THEN ’ Weekday’
WHEN 10 THEN ’ Weekend Day’
END + ’ of every ’ + CONVERT(VARCHAR, [schedule].[freq_recurrence_factor]) + ’ month(s)'
ELSE ''
END
,[Frequency] =
CASE [schedule].[freq_subday_type]
WHEN 1 THEN 'Occurs once at ’ +
STUFF(STUFF(RIGHT(‘000000’ + CONVERT(VARCHAR(8), [schedule].[active_start_time]), 6), 5, 0, ‘:’), 3, 0, ‘:’)
WHEN 2 THEN 'Occurs every ’ +
CONVERT(VARCHAR, [schedule].[freq_subday_interval]) + ’ Seconds(s) between ’ +
STUFF(STUFF(RIGHT(‘000000’ + CONVERT(VARCHAR(8), [schedule].[active_start_time]), 6), 5, 0, ‘:’), 3, 0, ‘:’) + ’ and ’ +
STUFF(STUFF(RIGHT(‘000000’ + CONVERT(VARCHAR(8), [schedule].[active_end_time]), 6), 5, 0, ‘:’), 3, 0, ‘:’)
WHEN 4 THEN 'Occurs every ’ +
CONVERT(VARCHAR, [schedule].[freq_subday_interval]) + ’ Minute(s) between ’ +
WHEN 8 THEN 'Occurs every ’ +
CONVERT(VARCHAR, [schedule].[freq_subday_interval]) + ’ Hour(s) between ’ +
ELSE ''
END
,[AvgDurationInSec] = CONVERT(DECIMAL(18, 2), [jobhistory].[AvgDuration])
,[Next_Run_Date] =
CASE [jobschedule].[next_run_date]
WHEN 0 THEN CONVERT(DATETIME, ‘1900/1/1’)
ELSE CONVERT(DATETIME, CONVERT(CHAR(8), [jobschedule].[next_run_date], 112) + ’ ’ +
STUFF(STUFF(RIGHT(‘000000’ + CONVERT(VARCHAR(8), [jobschedule].[next_run_time]), 6), 5, 0, ‘:’), 3, 0, ‘:’))
,[Fail Notify Name] =
CASE
WHEN oper.enabled = 0 THEN 'Disabled: '
ELSE ''
END + oper.name
,[Fail Notify Email] = oper.email_address
END
FROM [msdb].[dbo].[sysjobs] AS [jobs] WITh(NOLOCK)
LEFT OUTER JOIN [msdb].[dbo].[sysjobschedules] AS [jobschedule] WITh(NOLOCK)
ON [jobs].[job_id] = [jobschedule].[job_id]
LEFT OUTER JOIN [msdb].[dbo].[sysschedules] AS [schedule] WITh(NOLOCK)
ON [jobschedule].[schedule_id] = [schedule].[schedule_id]
INNER JOIN [msdb].[dbo].[syscategories] [categories] WITh(NOLOCK)
ON [jobs].[category_id] = [categories].[category_id]
LEFT JOIN sysoperators oper
ON [msdb].[dbo].[job.notify_email_operator_id] = [oper.id]
LEFT OUTER JOIN
( SELECT [job_id], [AvgDuration] = (SUM((([run_duration] / 10000 * 3600) +
(([run_duration] % 10000) / 100 * 60) +
([run_duration] % 10000) % 100)) * 1.0) / COUNT([job_id])
FROM [msdb].[dbo].[sysjobhistory] WITh(NOLOCK)
WHERE [step_id] = 0
GROUP BY [job_id]
) AS [jobhistory]
ON [jobhistory].[job_id] = [jobs].[job_id];
