wait msiexec.exe /X {{GUID} /l*v “%PROGRAMFILES(X86)%\XYZ\Logs\Uninstall\Proofpoint Email Feedback Plug-in for Microsoft Outlook-msi.log” REBOOT=ReallySuppress /q encountering 1622 exit code error for above action script for one of the application, how do i can fix this. Any suggestion or help will be appreciated. Thanks in advance.
1622 usually means it cannot write to the installation log file. It’s not necessarily a failure though.
Have you tried running the command manually in the command prompt to see if it has an issue?
Thanks Zevanty! instead of wait we tried the dos format which helped.
