i am trying to test a kaspersky installer which is an exe. I tested this installer locally from cmd. Runs like a charm. The command is something like this:
“ksv.exe” -d c:\temp
If i run it directly from cmd - as a system or as a current user - this runs perfectly showing me the eula next.
When i run it through BigFix - i can clearly see the software running in task manager - but i dont see the eula pop-up - also the cpu usage is 0 - seems like its waiting for my instructions but is stuck.
If i run the exact same action script but remove the -d c:\temp - the eula pops up like a charm.
So it doesnt seem like a priv issue. Anyone has faced something similar?
