I have configured my web-reports in accordance with the technote, Link:
Setup for SSL on Tivoli Endpoint Manager Web Reports
but for some resaon the port 52312 does not listen when the switch to SSL. Even if I change to the default SSL report 443 the result is the same. The Web-report-modul seems to works very well when checking the logs, even the web-page shows nothing. Here is what the logs tells:
Mon, 03 Dec 2012 06:44:04 -0800 – 4512 – Opening socket with IP address: ::
Mon, 03 Dec 2012 06:44:04 -0800 – 4512 – Can’t listen on address
: Input/output error; system lib; system lib (class SSL_CTX_use_certificate_chain_file_Failed)
Mon, 03 Dec 2012 06:44:04 -0800 – 4512 – No sockets were configured. Aborting.
Mon, 03 Dec 2012 06:44:04 -0800 – 4512 – HTTPServer error: class HTTPServerInitalizationError
The web-reports is running on windows 2008 R2 server, TEM 8.3.2, every ports is open both at the external and the internal firewall.
Does anyone have a suggestion?
