The value range listed for SleepIdle & WorkIdle is 1-500 (MilliSeconds)
If for some reason I wanted 50% CPU usage, could I set these both to 500, so that work+sleep would equal 1000, or do I have to have both values add up to something less than 500?, in which case I would need to set them to 250 each max.
To be clear, I’m not actually interested in setting these values this high, I am just trying to understand if all possible values between 1 through 500 are valid for the Idle settings independently or if there are other constraints.
That page does not answer my question about the maximum combined value of WorkIdle+SleepIdle. It seems like they can both be set to 500, but I wanted to know if that is true or not.
I’m not sure what your concerns are. Although the available range for those parameters are 0-500, it works as long as the tech note introduces how the agent work. You keep in your mind in order not to exceed 100% of CPU usage by your own.
