@JasonWalker
I was trying to upgrade the Skype to the latest version but it’s failed at the below lines and the Exitcode is 128 for few of the computers and for some others Exitcode is 0.
have you tried to download the file manually from the server. I know in out network the FW can block traffics or sometimes there is a problem with SSL bypass.
I had encountered that at one point on my former deployment. Based on where it’s failing you may have the same issue I did - that there was another application installed that included “Skype” in the name, that caused that relevance query to have a plural result. The plural results trigger a relevance error. In my case it was a custom toolbar, and so the content team added “Toolbars” to the relevance query to exclude it.
This statement -
wait msiexec /x {name of key whose (name of it starts with "{" and (it contains "Skype" AND it != "Skype Click to Call" AND it does not contain "Toolbars" AND it does not contain "Skype for Business") of (value "DisplayName" of it as string)) of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" of registry} /qn /norestart
includes the relevance substitution that is used to find the name of Skype’s Uninstall registry key, and then uses ‘msiexec /x’ to remove Skype.
Either log on to the machine and search the registry, or use the Fixlet Debugger or an Analysis to try retrieving this query -
(name of it, (if exists (value "DisplayName" of it) then value "DisplayName" of it as string else "<no displayname>") of it )of keys whose (name of it starts with "{" and (it contains "Skype" AND it != "Skype Click to Call" AND it does not contain "Toolbars" AND it does not contain "Skype for Business") of (value "DisplayName" of it as string)) of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" of registry
If any of those clients have multiple results, then either post back here or open a PMR ticket, we may be able to ask the content team to refine their relevance to exclude it.
Bit more on this too… We use Avaya Softphone on some desktop that throws more into the mix…
Relevance.
exists keys whose ((it contains “Skype” AND it != “Skype Click to Call” AND it does not contain “Toolbars” and it does not contain “Update for Skype for Business” AND it does not contain “Skype Integration” AND it does not contain “Skype Web Plugin” AND it does not contain “Microsoft Skype for Business MUI” AND it does not contain “Skype Meetings App”) of (value “DisplayName” of it as string)) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry
Action Script
wait msiexec /x {name of key whose (name of it starts with “{” and (it contains “Skype” AND it != “Skype Click to Call” AND it does not contain “Toolbars” AND it does not contain “Skype for Business” AND it does not contain “Skype Integration” AND it does not contain “Skype Web Plugin” AND it does not contain “Microsoft Skype for Business MUI” AND it does not contain “Skype Meetings App” ) of (value “DisplayName” of it as string)) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry} /qn /norestart
wait __Download\SkypeSetupFull.exe ALLUSERS=1 FEATURE_IEPLUGIN=0 FEATURE_FFPLUGIN=0 INSTALLLEVEL=1 STARTSKYPE=FALSE TRANSFORMS=:RemoveStartup.mst /VERYSILENT /NOLAUNCH
Sure Jason… Actually, I was slightly incorrect in that yes, we use Avaya SoftPhone
Avaya Agent | 1.6.2.3007
Avaya Collaboration Services | 6.5.3
But the thing that caused the modification of the fixlet was Jabra… We use the Jabra Pro bluetooth headsets for the Avaya Communicator and this uses
DisplayName Jabra Direct
DisplayVersion 3.8.689.0
Also DisplayName JabraDirect (From HKLM\software\microsoft\windows\currentversion\uninstall (both 32 and 64 bit)
@Pete_F I’m not sure how Avaya makes a different then…it looks like it wouldn’t be detected by the relevance that finds the Skype uninstall string. What is actually modified in your custom fixlet?
In my case, the plugin for HoloLens had “Skype” in the display name string.
Q: (name of it, (if exists (value “DisplayName” of it) then value “DisplayName” of it as string else “”) of it )of keys whose (name of it starts with “{” and (it contains “Skype” AND it != “Skype Click to Call” AND it does not contain “Toolbars” AND it does not contain “Skype for Business”) of (value “DisplayName” of it as string)) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry
A: {3B7E914A-93D5-4A29-92BB-AF8C3F66C431}, Skype™ 7.40
A: {3C66E71B-4243-46FF-8C4A-29A926968FBC}, Skype Meetings App
T: 60774
It looks like “Skype Meetings App” is throwing it off.
Does changing the actionscript to the following fix the issue?
wait msiexec /x {name of key whose (name of it starts with “{” and (it contains “Skype” AND it != “Skype Click to Call” AND it does not contain “Toolbars” AND it does not contain “Skype for Business” AND it does not contain “Skype Meetings App”) of (value “DisplayName” of it as string)) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry} /qn /norestart
