I created a reg key that will be used to help track the state of some custom support levels we are developing. The key is located under HKLM\Software\BigFix and is named SupportLevel
When I evaluate the following relevance on my workstations it returns Error: Singular expression referes to nonexistent object.
value “SupportLevel” of key “HKLM\SOFTWARE\BigFix” of registry
I stuck a string value of “SupportLevel” under my Bigfix key and it worked fine. Start from scratch and see that you are looking where you think you are looking.
exists key “HKLM\Software\Bigfix” of registry
(if it comes back as false, try swapping “registry” with “x32 registry”, “x64 registry”, etc.)
Once you have a true result, try the following (which will show you items that are below that key):
names of values of key “HKLM\Software\Bigfix” of registry
