Shortcut script works on XP but not 2000
(imported topic written by thuy.cortes91)
On both OS I can double click on the script and it creates the shortcut, but when I deploy through BES it only works on WinXP.
prefetch RunAsCurrentUser.exe sha1:5512ef51a98dff1aa910a8189a0361c161fa703f size:212992 http://software.bigfix.com/download/bes/util/RunAsCurrentUser-2.0.2.exe
createfile until ENDFILE
set WshShell = WScript.CreateObject(“WScript.Shell”)
strDesktop = WshShell.SpecialFolders(“AllUsersDesktop”)
set oUrlLink = WshShell.CreateShortcut(strDesktop & “\Synapsys - Sign-On.url”)
oUrlLink.TargetPath = “http://crm-sql/SynapsysDesktop/login.aspx”
oUrlLink.Save
ENDFILE
copy __createfile AddSynapsys.vbs
waithidden __Download\RunAsCurrentUser.exe --w “{pathname of system folder & “\cscript.exe”}” AddSynapsys.vbs
*User is logged on and it still doesn’t work on Windows 2000 computers… does it have anything to do the the RunAsCurrentUser.exe
(imported comment written by thuy.cortes91)
I think the problem is that the script only works if someone with local admin rights is logged in. How would I run as a local admin instead of current user?
If you take out RunAsCurrentUser.exe, it should run under the SYSTEM context:
waithidden
"{pathname of system folder & "\cscript.exe
"}" AddSynapsys.vbs
Thank you so much!!!
