I understand that parameters can be set in OSD, but was wondering if you can recognize the max/native value of the display and then have that be the set value. Environment has several laptop makes/models, even some that have different native resolutions for the same model.
Hello.
As far as I know it’s possible, if you want to provide the display resolution, only to define specific values, otherwise the default values will be set.
Could it depend on the video driver bound? Could you please check if any video driver is present for those models? If one of them is providing the desired resolution, you can explicitly bind it (“Current manual binding”) to the OS image binding grid.
Thanks.
Thanks Segio - I will verify that we have the video driver binded. As of right now, everything is being set to 1024x768 during imaging. I have too many models to select a specific resolution so I was hoping for something that sets “max” or “preferred.”
Apologies for necro.
I stumbled upon this same issue and have found a method that consistently works without any jank or 3rd party software required. Run the task and it does what it says. I have shared the task here:
https://bigfix.me/fixlet/details/27417
