For those that might not be aware, BigFix has an Ideas Portal to enable improved collaboration with our customers and partners around potential new features and capabilities to BigFix Product.
Below, please find the Ideas created in the Ideas Portal for the month of September 2021 for your reference. You can view their details, as well as vote or provide comments to those that interest you and your organization.
We will work to provide similar references here on the BigFix Forum in this Ideas category on a monthly basis for awareness and to foster additional collaboration.
Donât have an account? Itâs easy to sign up @ https://bigfix-ideas.hcltechsw.com/portal_users/new.
Thank you!
| URL | Idea name | Workspace name |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-98 | Update DISA STIG checklist for Microsoft SQL Server 2014 to latest | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-97 | Compliance Patch report dont have option to report selected patches against one or more computer group | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-96 | Improve/Add Functionality to Exception Management | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-95 | Support Platform Updates in CMEP for MS Defender | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-94 | Requesting STIG Checklist for Mozilla Firefox STIG - Ver 5+ | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-93 | For V-54381, update the check content and desired values to consider âemailâ an acceptable configuration setting | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-92 | Add CrowdStrike Falcon as supported by Client Manager for Endpoint Protection | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-232 | Security and Audit logs missing basic details in BFI Version 10.0.4 | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-231 | Add ability to remove multiple Users within the BigFix Inventory Appplication | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-128 | OS Install Date inspector | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-127 | Integrate Kollective for Software Distrubution | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCM-I-7 | Add Oculus for Business for supported Device | Modern Client Management |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-19 | Consolidate Cloud Analyses Properties | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-196 | Schedule the âStart Client Downloads Before Constraints Are Satisfiedâ | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-195 | Augment WebUI Deployment View | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-194 | HTTPS downloads where possible | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-193 | Web Reports View User Enhancement | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-192 | Button to Remove All Superseded Patches | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-191 | Add Patch Support for PowerShell Core 7.1.x | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-190 | Add a âMove group to Top of Baselineâ and âMove group to Bottom of Baselineâ | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-189 | Add support of Microsoft MSA | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-188 | Add support for CentOS Streams | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-187 | Support for RHEL8âs new patching via Module streams | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-233 | Increase baseline performance (i.e. increase recommended number of components per baseline) | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-232 | Display last logon details to users on successful login | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-231 | Ability to configure a maximum number of components per baseline | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-230 | Ability to configure the BigFix Clientâs startup type on Windows | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-229 | Add High Availability/DSA Support to WebUI | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-228 | Add support for Nutanix | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-227 | Configure Relay Authentication to accept/authenticate new endpoints | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-226 | Ability for customers to see what relevance conditions are not met | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-225 | Ability to provide comments to relevance conditions | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-224 | Add Web Reports Funtionality to WebUI | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/IDEACNCTNS-I-2090 | Integrating Azure Active Directory - SAML with BigFix | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-223 | Baseline Component Applicability should reflect the status of the component when the baseline was created | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-222 | Add ldaps thru load balancing for BigFix Console | Platform |
