"Select Operator" does not appear
“Daily Power Statistics by Computer” in, “Select Operator” does not appear.
In addition, “Daily Power Statistics” There is no change in results.
Is there a cause and how to deal with it?
Best regards,
Hi mashiki,
Did you enable power tracking in the Power Tracking Information Dashboard?
Hi Ben,
“Power Tracking Information Dashboard” is a start (enable), but values such as “Total cost” are not updated at all.
mashiki
Hi Ben,
Thank you.
The cause did not become clear, but has been recovered.
mashiki
We have a similar issue.
My account does not appear in the “Select Operator” pull-down, but the account for another master operator does. This report usually doesn’t return any data, but if we refresh the report several times, sometimes data gets populated. This is repeatable in both Firefox and IE, and is not unique to any specific device on our network.
No issues with any of the other “power management” related reports, just this one.
Hey guys,
To investigate further, we probably will need a support case opened and it would be really helpful if you had a way to reproduce that you could show us and we could troubleshoot…
Thanks!
Dear Ben
Dear mikelocklar
We appreciate the advice.
Also, if any trouble, please back up.
Thank you very much.
