Searching for existence of key value within regitry key
(imported topic written by rkc91)
Folks
Want to search for a value of key in registry eg. search for SpeedDuplex within HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}
exists value “SpeedDuplex” of Key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}” of registry
(imported comment written by rkc91)
It return false as it is in one of the subkeys on my machine it is under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0008
if you just want to find out which adapter is “physical” you can use a part of the relevance in this post.
http://www.pimpmybes.com/viewtopic.php?id=194
or do
exists value “SpeedDuplex” of keys of Key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}” of registry
Thanks I was missing keys of key
(imported comment written by brolly3391)
Hey rkc,
Now that I look at the registry key that you are checking, I see that you actually are trying to go a level deeper.
It seems that you are trying to get
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0000
SpeedDuplex
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0001
SpeedDuplex
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0002
SpeedDuplex
and so on.
You can ues keys of key to iterate through all of the subkeys. Notice that keys is plural and so will return all matching objects under key.
Check this out:
q: values “SpeedDuplex” of keys of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}” of registry
As far a technique goes, you can even get fancier. For example if you know the name of a key that is further down the tree you can do another layer of key object. If you wanted to find all values under the following set of keys
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}???\Ndi\Params\RequestedMediaType
you could use:
q: values of key “NDI\Params\RequestedMediaType” of keys of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}” of registry
A: Speed & Duplex
A: 0
A: enum
Depending on what you are actually trying to pull, there might be a BES inspector that can directly pull it or you can try out the method suggested above by Martin Forster. Usually it is more efficient to use the inspectors when they exist.
Check here: http://support.bigfix.com/fixlet/documents/WinInspectors-2006-08-10.pdf under the Networking Objects section for ideas and examples.
Cheers,
Brolly
Thanks brolly33 and Martin
I intended to find out first active nic using active devices from HKLM\SYSTEM\CurrentControlSet\Services relating the nic to find it speed from “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}” of registry
