hi ,
when i am trying to execute the below code its getting failed in TEM but manually it is getting succeed.
can any one please help me fix the issue.
dos QualysCloudAgent.exe CustomerId={9b4482a2-51bf-4496-82bd-4f4ac9bd479f} ActivationId={4488f2c7-3055-4d51-a344-727954047a37}
              Thanks Jason,
it tried with below steps but no luck
dos QualysCloudAgent.exe CustomerId={{9b4482a2-51bf-4496-82bd-4f4ac9bd479f}} ActivationId={{4488f2c7-3055-4d51-a344-727954047a37}}
dos QualysCloudAgent.exe CustomerId={(9b4482a2-51bf-4496-82bd-4f4ac9bd479f} ActivationId={4488f2c7-3055-4d51-a344-727954047a37}}
dos QualysCloudAgent.exe CustomerId={(9b4482a2-51bf-4496-82bd-4f4ac9bd479f}} ActivationId={{4488f2c7-3055-4d51-a344-727954047a37}}
can you please help.
                trn
                    June 10, 2020,  3:38pm
                  4
              You need to read the linked reply above.  You tried a lot of combinations, but not the correct one.
Sorry, I’m not going to just give you the answer, it is in Jason’s link and you need to understand it for future use.
              I know it can be confusing, try reading the post again.  That should lead you to try
dos QualysCloudAgent.exe CustomerId={{(9b4482a2-51bf-4496-82bd-4f4ac9bd479f} ActivationId={{4488f2c7-3055-4d51-a344-727954047a37}
(Note I’m not sure if QualysAgent actually works, just that this should be the syntax for escaping the curlybrackets.  If that doesn’t work we can check next steps).
              hi Jason,
sorry the given step is not working as expected
                trn
                    June 10, 2020,  5:53pm
                  7
              We have a fixlet that installs Qualys agent - used to deploy PoC - works like a charm (as usual with Bigfix).
