Schedule-Wake-On-LAN
(imported topic written by jr6591)
In the new PM site, does the Schedule-Wake-On-LAN task have the ability to in 1 task, wake up the computer at 4 different times.
For example, at 1am , 2am , 4 am and 6 am
I had done this in the old site.
Also, when I do create the task for 1am, any reason why the long string at the end of the task. In this case - 2601288113551
runhidden __Download\StandbyTool.exe /W “Tue, 26 Oct 2010 01:00:00 {local time zone as string}” repeat daily 1 /n “WFS - 1am 2601288113551”
I’m guessing it’s there to prevent two tasks with the same name from overwriting or conflicting with each other. The standby tool is essentially creating a scheduled task in Windows that will wake the computer from standby, so all of the task names must be unique.
(imported comment written by jr6591)
I figured that, but this makes it a little difficult to build one task to deploy 4 wakeup times. My intention is to have 1 task that wakes up the PC 4 times.
I would have to create 4 tasks, steal the one line from 3 of the tasks and put it into the one task i intend to use.
Any thoughts on this?
My only thought is… don’t overthink it…
Just because the wizard generates that random number in the task name doesn’t mean you have to use it. I have a task that does something very similar (waking systems 4 times a day, in fact). You can always make the one scheduled wakeup task and then copy/paste the command that the wizard generates 3 times. Then modify the start time (denoted by /W) and name (denoted by /n) on each copied command and you should be good to go.
As long as you don’t make and deploy another scheduled wakeup with the same name(s), you should be fine. I think that (seemingly) random string is there so that tasks generated by the wizard with the same names can’t overwrite themselves by mistake.
