Schedule wake on lan not working
(imported topic written by TivoliDon)
Hello,
My schedule wake on lan is not working. However when I right click any computer and select “Send Wake on lan request”, it works perfectly fine.
I have configured forwarders properly for each subnet and I make sure they are switches on when I initiate Wake on Lan process. Still the schedule wake on lan is not working.
(imported comment written by Zakkus)
Does my answer here help you:
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=410993&tstart=0
-Zak
(imported comment written by TivoliDon)
Zak,
I have enabled Wake on Lan medic and I have also added some registry entries for web reports as per some other post in other forums.
It still doesn’t work. Unfortunately I cannot open a support case I am doing a POC.
Check the WOL Medic logs under “C:\Program Files (x86)\BigFix Enterprise\BES Server\Applications\BESWoLMedic” on your BES server machine. The logs will let you know if it is having a problem with some parameters (like webreport user name or password)
