We are trying to Setup Automation plans that runs every month by itself. Scheduler on Automation Plan Screen only allows one time setup to Set Start . We like to have Each month same day kind of. Is there any option other than API calls to make it work.
Any help with reference to API also helps
Murali
@muralidhar, presently the only mechanism would be a REST API integration. Documentation on the SA REST API is available at https://help.hcltechsw.com/bigfix/10.0/lifecycle/Lifecycle/ServerAutomation/SAUsersGuide/Server_Automation_configuration/c_server_automation_rest_api.html
Thanks a lot for reply
