SCA Web Reporting Visual Issues
Is there any sort of troubleshooting step to make the Home page look better? The main dashboard GUI just doesn’t look that great.
Probably not.
You might be able to adjust the CSS or perhaps the page itself, but I don’t know if there is a built in way to do that sort of customization, so it may involve trying to hack the actual page on the server, which would probably be messy.
If you want something better looking, then you may need to build your own dashboard using APIs.
Related: Issues with CIS Benchmark Tools Incorporated into BigFix/SCA
Weird, after a reboot, the dashboard looks much cleaner. The text and graphics are organized and do not overlap anymore.
