Running IVR without Qualys or Tenable
@Aram Is it possible to use IVR with CSV data only? I have installed Retriever 4.3, and closed out of the Setup UI after configuring the BigFix API section. The system is applicable for Task 252: WARNING: BigFix IVR Retriever v4 has an incomplete configuration. WIll IVR still function properly without connecting to Tenable or Qualys?
It should be possible, yes. @bigfix_anurag , can you verify and provide any additional comments and/or guidance?
Yes, it is possible.
The warning fixlet may take some more time to become “not applicable”
The warning fixlet will remain there but this can be ignored. The functionality will work fine.
@bigfix_anurag Can IVR 4 run under a service account and use that to authenticate with SQL Server, so we can avoid using a SQL Server account?
Yes, it will work. The service account must have access to the SQL Server and, at a minimum, be granted write permissions to the target database.
