Running a Powershell script using bigfix action script
I am trying to run the following script with no success.
It will be tested on windows machines but something is getting messy with the curly brackets.
wait "c:\Windows\system32\windowspowershell\v1.0\powershell.exe" -command
try{
$BLV = Get-BitLockerVolume -MountPoint $env:SystemDrive
        $KeyProtectorID=""
        foreach($keyProtector in $BLV.KeyProtector){
            if($keyProtector.KeyProtectorType -eq "RecoveryPassword"){
                $KeyProtectorID=$keyProtector.KeyProtectorId
                break;
       $result = BackupToAAD-BitLockerKeyProtector -MountPoint "$($env:SystemDrive)" -KeyProtectorId $KeyProtectorID
return $true
catch{
     return $false
Your help will be appriciated.
Welcome to BigFix!
You could just use the PowerShell script type directly if you are on a recent version of BigFix. Otherwise, the curly-bracket is evaluated as a Relevance substitution; you need to escape the open-curly-bracket by doubling it as in
try {{
    Do something
See Tip: Escaping curly brackets for substitutions in ActionScript for more examples
Ok using the powershell script type works well.
Thanks alot
