Runascurrent vbs script
(imported topic written by bc6591)
I cant seem to get the RunAsCurrentUser to work as follows:
continue if {exists current user}
wait \bigfix\install\bes\RunAsCurrentUser.exe --w script \bigfix\Install\Director\AddProxyOverride.vbs
Can anyone enlighten me? I know the script works. I am using the RunAsCurrentUser-2.0.exe ( I just renamed because it didnt seem to work. The Task says that it completed. but no change. It is a small script that adds one ip address to the proxy exceptions for the user.
Thanks,
bc
I see a couple issues here… Are you trying to run RunAsCurrentUser.exe from a network share? That’s probably not a very reliable method.
You could use this instead:
prefetch RunAsCurrentUser.exe sha1:5512ef51a98dff1aa910a8189a0361c161fa703f size:212992 http://software.bigfix.com/download/bes/util/RunAsCurrentUser-2.0.2.exe
createfile until ENDFILE
' Add the contents of your VBScript here
ENDFILE
copy __createfile AddProxyOverride.vbs
waithidden __Download\RunAsCurrentUser.exe --w "{pathname of system folder & "\cscript.exe"}" AddProxyOverride.vbs
Note: I did not test this action script.
(imported comment written by bc6591)
We tried a variation of this and it worked just fine.
Thanks, Boyd
