I’m receiving this exit code when running “Run Capacity Scan and Upload Results” action. The action looks like it is failing at the below sections. Does anyone have any insight to what might be causing this? I have already tried restarting the WMI service which i seen fixed someone issue similar to ours which did not work. Any help is appreciated.
Client Log:
Command succeeded parameter “sourceReleaseDate” = “2017-10-04” (action:50126)
Command succeeded parameter “forceResultsUpload” = “false” (action:50126)
Command succeeded parameter “homefolder” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT” (action:50126)
Command succeeded parameter “citconfigfile” = “C:\Windows\cit” (action:50126)
Command succeeded parameter “citinstalldir” = “C:\Program Files (x86)\Tivoli\cit” (action:50126)
Command succeeded parameter “outdir” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_scans” (action:50126)
Command succeeded parameter “compressedfile” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\11667147_tlm_hw.zip” (action:50126)
Command succeeded parameter “slash” = “” (action:50126)
Command succeeded runhidden cmd /c mkdir “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_scans” (action:50126)
Command succeeded runhidden cmd /c mkdir “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT” (action:50126)
Command succeeded parameter “scanResultsLimit” = “7” (action:50126)
Command succeeded parameter “cpacityConfigXml” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_config.xml” (action:50126)
Command succeeded parameter “logfilepath” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\11667147_cit_tlm_hw.log” (action:50126)
Command succeeded delete “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_config.xml” (action:50126)
Command succeeded createfile until (action:50126)
Command succeeded move __createfile “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_config.xml” (action:50126)
Command succeeded parameter “epoch” = “1537297085” (action:50126)
Command succeeded parameter “timestamp” = “201809181458” (action:50126)
Command succeeded parameter “scanfilepath” = “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\tlm_hw_scans\tlm_hw_201809181458_1537297085.xml” (action:50126)
Command succeeded parameter “lastscanfile” = “” (action:50126)
Command succeeded delete “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\runcit_tlm_hw.bat” (action:50126)
Command succeeded move __createfile “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\runcit_tlm_hw.bat” (action:50126)
Command started - waithidden cmd.exe /c ““C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\runcit_tlm_hw.bat” > “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\11667147_cit_tlm_hw.log” 2>&1” (action:50126)
Command succeeded (Exit Code=255) waithidden cmd.exe /c ““C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\runcit_tlm_hw.bat” > “C:\Program Files (x86)\BigFix Enterprise\BES Client\LMT\CIT\11667147_cit_tlm_hw.log” 2>&1” (action:50126)
Command succeeded (evaluated false) continue if {exit code of action = 0} (action:50126)
At 14:58:05 -0400 -
ActionLogMessage: (action:50126) ending actionEx
At 14:58:06 -0400 -
Action Info:
Completed //*********************************** CREATE FILE “runcit_tlm_hw.bat” END *********************************** //
Completed delete "{parameter “homefolder” as string}\runcit_tlm_hw.bat"
Completed move __createfile “{parameter “homefolder” as string}\runcit_tlm_hw.bat"
Completed waithidden cmd.exe /c “”{parameter “homefolder” as string}\runcit_tlm_hw.bat” > “{parameter “logfilepath” as string}” 2>&1"
Failed continue if {exit code of action = 0}
continue if {(exists file ((parameter “scanfilepath”) as string))}
// Validate the generated capacity scan output and exit with error code when one of the key nodes in not present in XML file
//*********************************** CREATE FILE “checkCapacityScanOutput.vbs” START *********************************** //
createfile until eofdelim
Function checkFile(fileName)
Set xmlDoc = CreateObject(“Msxml2.DOMDocument”)
xmlDoc.load(fileName)
Set objNodeList = xmlDoc.getElementsByTagName(“ComponentID”)
If objNodeList.length <> 1 then
checkFile=1
Exit Function
End If
Set objNodeList = objNodeList.item(0).getElementsByTagName(“SerialNumber”)
checkFile=2
Exit Function
Else
If objNodeList.item(0).Text = “” then
checkFile=3
Exit Function
End If
End If
Set objNodeList = xmlDoc.getElementsByTagName(“PhysicalProcessor”)
If objNodeList.length = 0 then
checkFile=4
Exit Function
Thanks.
