hi, when i tried to push any patch to RHEL 7 it shows patch failed at the end and getting below message into RHSMPluing.log
4704 : 2017-09-08 00:00:03 : WARNING : All Entitlement Certificate(s) in ‘rootCertDir’ cannot access: https://cdn.redhat.com/content/dist/rhel/workstation/7/7Workstation/x86_64/oracle-java/os/repodata/repomd.xml. This is due to either (1)Expired Cert,(2)Cert is not entitled to access content, (3)Redhat CDN is down, (4) Your network / proxy is blocking RHSMPlugin.exe / RHSMDownloadCacher.exe
4704 : 2017-09-08 00:00:03 : WARNING : Download failed. Please enable DEBUG logs for more information.
4704 : 2017-09-08 00:00:03 : INFO : ******************************************
4704 : 2017-09-08 00:00:03 : INFO : Repo list Summary for: workstation-7-x86_64
I think the log has explained the issue quite clear that the Entitlement Certificate does NOT have access to the required repo.
This is due to either (1)Expired Cert,(2)Cert is not entitled to access content, (3)Redhat CDN is down, (4) Your network / proxy is blocking RHSMPlugin.exe / RHSMDownloadCacher.exe.
