Also, this is slightly off the topic of BigFix, but is on the topic of SIDs:
That is an blog entry from earlier this week by Mark Russinovich of Sysinternals fame and the author of the NewSID utility. While I think having a unique machine SID is still a good thing because some programs rely on it, apparently we have had some misconceptions about the importance of the machine SID for quite a long time. It is a pretty interesting read.
last 24 of (value “V” of key “HKLM\SECURITY\SAM\Domains\Account” of registry as string)
My recommendation would be to run that relevance on one of your machines and then post the results in the aforementioned thread… then I can update my SID converter relevance so that you can use a single query to get a properly formatted result.
I updated your other post with the relevance below
“S-1-5-21” & “-” & hexadecimal integer ((concatenation of (characters (6;7;4;5;2;3;0;1) of it)) of ((first 8 of (concatenation of substrings separated by “,” of (last 24 of (value “V” of key “HKLM\SECURITY\SAM\Domains\Account” of registry as string)))))) as string & “-” & hexadecimal integer ((concatenation of (characters (6;7;4;5;2;3;0;1) of it)) of (last 8 of preceding text of position (length of it - 8) of (concatenation of substrings separated by “,” of (last 24 of (value “V” of key “HKLM\SECURITY\SAM\Domains\Account” of registry as string))))) as string & “-” & hexadecimal integer ((concatenation of (characters (6;7;4;5;2;3;0;1) of it)) of (last 8 of (concatenation of substrings separated by “,” of (last 24 of (value “V” of key “HKLM\SECURITY\SAM\Domains\Account” of registry as string))))) as string
This works great for the Local Machine SID, but i’m looking for the Machines DOMAIN SID
Get Local Machine SID
PsGetSid v1.43 - Translates SIDs to names and vice versa
That is some mighty nice relevance there mamacher. After seeing what a pain it is to get the local machine SID, I assumed it would be an equal pain to get the computer account SID, but it apparently can be done via BigFix inspectors:
component string of sid of security account (computer name & “$”)
Note that this will throw an error if the machine is not on a domain, so you could do this to make it look prettier:
if exists security account (computer name & “$”) then component string of sid of security account (computer name & “$”) else “N/A”
One quick note though: you are actually having the computer query AD for the computer account SID with this. If you ultimately want the information in BigFix or it is just a convenient place to store it, then go ahead and do that. Since the SIDs are stored on the domain controllers, there are VBS scripts and other utilities that can relatively easily export this information to a CSV without having thousands of computers make an individual query. That being said, I am lazy and love having BigFix do the work for me, so I just added this to one of my own analysis and just set it to evaluate once a day.
And, as always, be careful with relevance that causes the end-point to query the AD server. If you cause 1000s of computers to hit your AD server all at once you may overwhelm the AD server.
