Retrieve all keys and their values under Registry Key
(imported topic written by hbkrules6991)
We use Big Fix to conduct our server inventory. Unforetunealy some things(like server owner) cannot be determine using BF so we have an application that we run that will put this info into the registry. We would then like to use BF to retrieve this info. How, using the registry key below, can we retrieve all the values of all the keys below it. Can it be done with one query? or multiple
HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo
Examples of keys are
Owner
Function
BackedUP
iLOCard
Location
etc…
Possible?
Thanks…
Something like this?
(name of it, it) of values of key “HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo” of registry
(imported comment written by hbkrules6991)
Thanks Jesse exactly what I needed. Since it will be in report format I would love to add the if exists in case it does not exists.
I tried
if exists (name of it, it) of values of key “HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo” of registry Else “NA”
but I know I did something wrong.
You have 2 options. If you are okay with the clients reporting nothing in the case where the key doesn’t exist, just make ‘key’ plural:
(name of it, it) of values of keys “HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo” of registry
Option 2, you can return a string in the case where the key doesn’t exist:
if (exist key “HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo” of registry ) then (it as string) of (name of it, it) of values of keys “HKEY_LOCAL_MACHINE\SOFTWARE\ServerInfo” of registry else “No Key”
I personally perfer the first one format because it’s easier to read and a little more efficient for the client, server, and console. However, reporting requirements often lead people to the second format (which really doesn’t cause that much more load).
Excellent, either one provides exactly what I need. thanks again!
