I should say off the bat that I am very new to BigFix. So, I apologize in advance for this being a complete newb question…
Not sure whether anyone has experienced this scenario before:
Users have both Adobe Reader and Acrobat installed, but have Acrobat set as their default pdf viewer. With my organization’s previous cleint management tool, whenever an update to Reader was applied, the default pdf viewer reverted back to Adobe Reader. Is there any relevance that can be applied to an action to retain the preference?
I think we just run the Adobe upgrader and let it do whatever it normally does… I am not sure if there is a way to tell the installer to avoid resetting the default pdf viewer…
I think we could figure out a way to set it back to Adobe if you were interested…
Adobe has a customizer that will spit out an .mst. Using that tool, you can specify which product (acrobat or reader) gets used as the default for opening pdf’s, along with a few other options such as opening withing the browser or not.
The installation package could not be opened. Verify that the package exists and that you can access it, or contact the application vendor to verify that this a valid Windows Installer package.
Please post if you have any insight into where I am going wrong.
