When I execute the baseline, the targeted system does not restart. Instead, steps 4 and 5 attempt to execute - failing, or not being relevant because the restart did not occur. Once all steps are complete, the action says the target is pending restart.
I was able to force restarts by including “restart 180” at the end of step 2, but in some cases the second task is not relevant. Am I missing something? Do I need to create a custom restart task?
The custom task did the trick. We’ve used the Restart Computers task in the past (stand-alone, not as part of a baseline), and it’s worked as expected. Did we just get lucky, with most of our clients already requiring a restart?
Usually if there is a reason for a restart, our Fixlet will detect it… so it is usually OK… it sounds like your particular situation needed a restart that was hard to detect…
