(imported topic written by hanspjacobsen)
I was wondering if there is a report that collects all information from sites that often is distributed between fixlet, task and analyze?
Hi Hans,
Can you be a little more specific about what your goal is? Is there a specific example you had in mind?
Noah
(imported comment written by hanspjacobsen)
Noah I was at a costumer meeting on Monday that are looking at BigFix and they saw the Dashboard of Windows vulnerability but it didn’t cover enough of their needs.
They have a project that is focused on applications vulnerability and want a report that shows all applications that are vulnerability both when it comes to patch level and if they are miss configured.
This report should cover all sites and not care if the vulnerability are in fixlet, task or window.
Hope this clarifies the costumers need.
Hans
Hans,
Have you looked into our Excel Connector? It might work to extract the data that you need.
http://forum.bigfix.com/viewtopic.php?id=3564
Choose the BES Fixlet object, which will include all of Fixlets, Tasks, Analyses and Baselines.
Fixlets can be filtered by choosing “fixlet flag = true”, and etc.
Lee Wei
