Reporting on running macOS processes
I’m trying to check if netbiosd is running on our Macs, after disabling it with
sudo launchctl unload -w /System/Library/LaunchDaemons/com.apple.netbiosd.plist
(per How to disable SMB 1 or NetBIOS in macOS - Apple Support)
Continuing with Apple’s guide, if I check the status of netbiosd with
sudo ps aux | grep -i netbiosd | grep -v grep
I get nothing back, indicating that it’s been disabled.
I then tried using the following relevance:
Q: exists "netbiosd" of processes
A: True
T: 200
I: boolean
but it tells me netbiosd is running. I tried re-arranging the statement, and it then tells me netbiosd is not running:
Q: exists process whose (name of it is "netbiosd")
A: False
T: 2724
I: boolean
Could someone help me understand the difference between these statements? Thank you
In the first case, you’re checking for the existence of a string, which is always true. If you recast it as:
Q: exists process "netbiosd"
you would also get false, because here, you’re instantiating a process object, rather than a string object named “netbiosd”,
Note that this example requires the “named” constructor for processes, which was introduced on macOS in 11.0.4.
https://developer.bigfix.com/relevance/reference/process.html
