(imported topic written by rkc91)
All
Justed wanted to get some ideas. How to one report on Resultant Set of Policy (RSoP) using Bigfix . Appreciate any feed back
rkc
All
rkc
Hi rkc,
Can you give us some more information about what you are looking for? Are you referring to Microsoft’s snap-in for AD?
(imported comment written by rkc91)
Yes the snap-in results and tie it with bigfix for reporting.
I believe option we have are either to create individual properties and report on them. Or if there is a way we can leverage snap-in results and tie it to bigfix
One can create a vbscript and run it from a machine with gpmc installed. Report are publish as html file. We cannot run this from individual machines as gpmc would not be installed on all machines.
Set GPMC = CreateObject(“GPMgmt.GPM”)
Set Constants = GPMC.GetConstants()
Set RSOP= GPMC.GetRSOP(Constants.RSOPModeLogging,"",0)
RSOP.LoggingComputer=“servername”
RSOP.CreateQueryResults()
RSOP.GenerateReportToFile Constants.ReportHTML,"\sharepath\servername.html
rkc
(imported comment written by tim7ad91)
rkc,
Do you want to use GPMC, or are you more interested in the RSOP data for each client? If it’s the client, wouldn’t the “gpresult” command line tool work better? You could redirect the output to a file and parse it grabbing the data you want, or format it with HTML and create a report.
One caveat though, there will not be any “user” RSOP data because BF runs under the system account. You could try to pass the current-logged-on user with the /SCOPE user switch and try. I’m not sure if it would work. For example:
gpresult /SCOPE “USER” /USER userid
To just get the machine RSOP data you would use:
gpresult /SCOPE “COMPUTER”
FYI… Windows Help and Support (XP and later) provide an HTML report of RSOP data as well. In XP, click Start, Help and Support. Under Tasks click “Tools”, from tools select “Advanced System Information”, then “View Group Policy settings applied”. I’m not sure if there is a command line way to get to this, but if there were I believe it would have what you want.
Hey folks,
One of our developers pointed out to me that in BES 7.0, we have implemented the following inspectors:
rsop user wmi
rsop computer wmi
Provides access to the Resulting Set of Policy WMI classes via the RsopLoggingModeProvider. This is used to examine the state of the GPO security policies.
Hope that helps,
Thanks Ben… that was good to know. I wasn’t aware of the inspector or the standalone rsop.msc.
Thanks Ben let me try that
Are there any more details on rsop inspector.
Thanks Tim7ad I already went thru that. I just wanted leverage results and tie to bigfix.
We have 7.0 server and client
But we get this The operator “rsop computer wmi” is not defined when checking on RelevanceDebugger.exe
Any ideas
rkc
Hi rkc,
Make sure you are using a 7.0+ version of the relevance debugger… then you can try something like:
selects “* from RSOP_GPO” of rsop computer wmi
I think this only works on Windows XP+.
