Reporting computers are less in action than they are actually in group
Hi All,
I have an issue in which, the reporting computers in group are around 29,000 and when I deploy the software deployment action on same Group ,it only reflects around 9000 systems in action.
This is causing issue as I am not able to deploy the software deployment task on all the 29000 computers.
I am attaching screenshot of group and action taken.
Please help.
Thanks,
Jatin khanna
@jatinkhanna
We will need more information if you want some help:
  • Are all your computers subscribed to the same site as the site where you’ve created your fixlet/baseline?
  • How many applicable computers do you have if you check the baseline/fixlet? (so not the action, but the fixlet/baseline itself)
Can you provide this info please.
