Renaming a registry entry
Im trying to determine if there is a key in the SNMP configuration called “public” if there is I just want to rename it to something else like “public1”
I can find if the key exists but changing it is the issue
I cant just delete it and add a new entry because there’s lots of keys below it associated to the “Public” key
Q: if exists key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration” of registry then exists key “public” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration” of registry else false
A: True
T: 0.152 ms
If you don’t want to remove the whole key, you can just use the ‘regdelete’ or ‘regdelete64’ command and specify a specific value. Syntax:
regdelete64 “” “”
If that doesn’t do it, then I don’t know a way to rename without writting a script to do it using Windows API calls.
Thank you jessewk
Correct I dont want to delete the Key, there lots of settings under that key,
I will have to come up with a script…
Thanks Again
