Removing SCCM from systems
Hi all,
I have a customer that needs us to remove SCCM from their systems. As I understand it, this does not show up in add/remove programs, and I was not able to find an uninstall string in the registry either.
I’m attempting to use the below, but it failed with the error “thread execution failed (2)”. I’ve confirmed that the .exe is most definately there in the directory.
waithidden “C:\windows\ccmsetup\ccmsetup.exe” /uninstall
As always, any assistance would be appreciated. Thanks.
The approach I’ve used in the past has been
waithidden cmd.exe /c "{pathname of windows folder & "\ccmsetup\ccmsetup.exe /uninstall"}"
That worked nicely. Thank you very much.
Thanks for sharing the info in the thread! It helped me a lot!
I understand that the thread is a bit dated, but the process of removing SCCM from systems can remain relevant over time. While the specific command you mentioned may have evolved with updates, the general approach often remains similar.
