Hi, I created a manual group and wish to delete it. Under “Edit” menu everything is grayout. I can’t find anywhere the option to remove the group. Please assist.
when you open the group, do you have the remove button near the top?
Are you sure your account is a Master Operator?
No… and I am using the admin account. Do you know where can I find the users permissions?
the admin is LDAP user unrestricted. that shouldn’t be enough?
Hi again, Any other idea?
User permissions for non Master Operators can be found under the user account or the role it is a part of.
