I have deployed Big fix remote controller to my network. I need to be able to remote onto servers and computers with out a prompt from a user. This problem was resolved however the inject ctrl alt delete seems not to work at all when you remote onto a server. Any idea’s or thoughts? As i can’t see anything in the client or roll out.
Alex,
Take a look at task id 47 (Configure Secure Attention Sequence to enable injecting Ctrl-Alt-Del in Remote Control sessions). This should do the trick!
-M
Hi Guys just to update you your answer aboved fixed my issue cheers for your help!!
