(imported comment written by tshambrey)
I am still having problems installing remote control that connect to my SQL server 2005 here are the things that I’ve done/checked
create sql database from SQL server manager studio Express TRCDB (also tried install without manually creating dbdata)
set .sql database is in mix mode authentication
sa is the owner of the database
download and installed the jdbc driver (location c:\sqljdbc_30\enu\sqljdbc.jar)
create empty folder c:\sqldata\ trcdb
changed WEBSITE Port from 80 to 9080 and 442 to 9443 (tried both ways)
create task (see below)
see error from task run
fixlet tast
delete __createfile
createfile until __ENDCREATE
INSTALLER_UI=SILENT
AdvancedWeb=NO
DATABASE_CHOICE=MSSQL_2005
DB2_DATABASE_CREATE_ON=
DB2_DATABASE_NAME=TRCDB
DB2_DROP_DATABASE=NO
DB2_JDBC_DRIVERS_PATH=
DB2_LIB_DIRECTORY=
DB2_LOCAL=NO
DB2_PASSWORD=db2pass
DB2_PORT=50000
DB2_PROFILE_PATH=
DB2_SERVER_ADDRESS=127.0.0.1
DB2_USERID=db2admin
DERBY_DB_NAME=TRCDB
FIPS_ON=NO
MSSQL_DATABASE_CREATE_DIR=C:\sqldata\trcdb\rc
MSSQL_DATABASE_NAME=TRCDB
MSSQL_DROP_DATABASE=YES
MSSQL_JDBC_DRIVER=C:\sqljdbc_3.0\enu\sqljdbc4.jar
MSSQL_LOCAL=YES
MSSQL_PASSWORD=12deffd@ts
MSSQL_PORT=1433
MSSQL_SERVER_ADDRESS=127.0.0.1
MSSQL_USERID=sa
OperatingSystem=Windows
ORA_DATABASE_NAME=TRCDB
ORA_JDBC_DRIVER=
ORA_PASSWORD=sys
ORA_PORT=1521
ORA_SERVER_ADDRESS=127.0.0.1
ORA_USERID=sys
SP800131A_ON=NO
USER_INSTALL_DIR=C:\Program Files\IBM\Tivoli\TRC\server
WAS_ADMIN_PORT=
WAS_ADMIN_SSL_PORT=
WAS_IPC_CONNECTOR_PORT=
WAS_RMI_PORT=
WAS_SOAP_PORT=
WEBSITE_ADDRESS=localhost
WEBSITE_ADMIN_EMAIL=admin@sdfsfd.com
WEBSITE_HTTPPORT=9080
WEBSITE_HTTPSPORT=9443
WEBSITE_SUBDIR=trc
WEBSITE_TARGET_DEFAULT_HTTP_OR_HTTPS=1
WizDownload_Location=
__ENDCREATE
copy __createfile __Download\TRC.properties
prefetch TRC_win.bfa sha1:0cac9a488297602a492c8cdfc941bc3960985dec size:428090371
http://software.bigfix.com/download/TRC/910_0303/TRC_win_0303.bfa
sha256:1282beebdb6f743f4c0c6bfe6d019fdf7ca916ff2ff69dcd751e6814e12a5c95
dos mkdir C:\sqldata\trcdb\rc
extract TRC_win.bfa
waithidden __Download\TRC.exe
continue if {exit code of action = 0}
dos rmdir C:\sqldata\trcdb\rc
delete __createfile
Error from task
The action failed.
This action has been applied 1 time and will not be applied again.
Status Failed
Start Time 8/22/2014 9:39:29 PM
End Time 8/22/2014 9:40:12 PM
Exit Code -1
Action Script Execution Detail
Completed delete __createfile
Completed createfile until __ENDCREATE
Completed INSTALLER_UI=SILENT
Completed AdvancedWeb=NO
Completed DATABASE_CHOICE=MSSQL_2005
Completed DB2_DATABASE_CREATE_ON=
Completed DB2_DATABASE_NAME=TRCDB
Completed DB2_DROP_DATABASE=NO
Completed DB2_JDBC_DRIVERS_PATH=
Completed DB2_LIB_DIRECTORY=
Completed DB2_LOCAL=NO
Completed DB2_PASSWORD=db2pass
Completed DB2_PORT=50000
Completed DB2_PROFILE_PATH=
Completed DB2_SERVER_ADDRESS=127.0.0.1
Completed DB2_USERID=db2admin
Completed DERBY_DB_NAME=TRCDB
Completed FIPS_ON=NO
Completed MSSQL_DATABASE_CREATE_DIR=C:\sqldata\trcdb\rc
Completed MSSQL_DATABASE_NAME=TRCDB
Completed MSSQL_DROP_DATABASE=YES
Completed MSSQL_JDBC_DRIVER=C:\sqljdbc_3.0\enu\sqljdbc4.jar
Completed MSSQL_LOCAL=YES
Completed MSSQL_PASSWORD=12deffd@ts
Completed MSSQL_PORT=1433
Completed MSSQL_SERVER_ADDRESS=127.0.0.1
Completed MSSQL_USERID=sa
Completed OperatingSystem=Windows
Completed ORA_DATABASE_NAME=TRCDB
Completed ORA_JDBC_DRIVER=
Completed ORA_PASSWORD=sys
Completed ORA_PORT=1521
Completed ORA_SERVER_ADDRESS=127.0.0.1
Completed ORA_USERID=sys
Completed SP800131A_ON=NO
Completed USER_INSTALL_DIR=C:\Program Files\IBM\Tivoli\TRC\server
Completed WAS_ADMIN_PORT=
Completed WAS_ADMIN_SSL_PORT=
Completed WAS_IPC_CONNECTOR_PORT=
Completed WAS_RMI_PORT=
Completed WAS_SOAP_PORT=
Completed WEBSITE_ADDRESS=localhost
Completed WEBSITE_ADMIN_EMAIL=admin@sdfsfd.com
Completed WEBSITE_HTTPPORT=9080
Completed WEBSITE_HTTPSPORT=9443
Completed WEBSITE_SUBDIR=trc
Completed WEBSITE_TARGET_DEFAULT_HTTP_OR_HTTPS=1
Completed WizDownload_Location=
Completed __ENDCREATE
Completed copy __createfile __Download\TRC.properties
Completed prefetch TRC_win.bfa sha1:0cac9a488297602a492c8cdfc941bc3960985dec size:428090371
Completed dos mkdir C:\sqldata\trcdb\rc
Completed extract TRC_win.bfa
Completed waithidden __Download\TRC.exe
Failed continue if {exit code of action = 0}
delete __createfile
