I’ve been trying for nearly a day now to install the console on a Win 7 x64 computer with no luck. I then tried to install on a Win 2003 x86 computer with no luck. Are there any definitive install guides for the console? I’m now finally stuck at
I fixed my own problem. I’ll list below the problems I had.
Windows firewall was on. Added exception for TCP 1433
x64 OS was used so I needed to modify the ODBC connection with the correct Data Sources (ODBC) tool. “C:\Windows\SysWOW64\odbcad32.exe” vs. Administrative Tools->Data Sources
Mixed mode authentication was turned off. Changed HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Microsoft SQL Server\MSSQL.1\MSSQLServer\LoginMode to 2 on my BES server
My DNS is turned off on my console so the masthead imported the FQDN of the bes server so I had to modify the ODBC settings to use IP instead of DNS.
