Relevance to return Dell Laptops affected by the Battery Return Progra
(imported topic written by Richard_Betts)
This relevance will return Dell Laptop Machines affected by the current recall program. You should NOT use this relevance without first cross checking it againts the latest recall information from dell and the affected battery model numbers.
The information on affected Battery models was retrived from;
https://www.dellbatteryprogram.com/Default.aspx
The relevance is below;
if (exists wmi) and exists selects “* from win32_Battery” of wmi and string value of selects “Manufacturer from Win32_ComputerSystem” of wmi as lowercase contains “dell” and (string value of it as lowercase contains “1k055” or string value of it as lowercase contains “c5340” or string value of it as lowercase contains “d6024” or string value of it as lowercase contains “jd616” or string value of it as lowercase contains “u5867” or string value of it as lowercase contains “x5333” or string value of it as lowercase contains “3k590” or string value of it as lowercase contains “c5446” or string value of it as lowercase contains “d6025” or string value of it as lowercase contains “jd617” or string value of it as lowercase contains “u5882” or string value of it as lowercase contains “x5875” or string value of it as lowercase contains “5p474” or string value of it as lowercase contains “c6269” or string value of it as lowercase contains “f2100” or string value of it as lowercase contains “kd494” or string value of it as lowercase contains “w5915” or string value of it as lowercase contains “x5877” or string value of it as lowercase contains “6p922” or string value of it as lowercase contains “c6270” or string value of it as lowercase contains “f5132” or string value of it as lowercase contains “m3006” or string value of it as lowercase contains “x5308” or string value of it as lowercase contains “y1333” or string value of it as lowercase contains “c2603” or string value of it as lowercase contains “d2961” or string value of it as lowercase contains “gd785” or string value of it as lowercase contains “rd857” or string value of it as lowercase contains “x5329” or string value of it as lowercase contains “y4500” or string value of it as lowercase contains “c5339” or string value of it as lowercase contains “d5555” or string value of it as lowercase contains “h3191” or string value of it as lowercase contains “td349” or string value of it as lowercase contains “x5332” or string value of it as lowercase contains “y5466”) of select “DeviceID from Win32_Battery” of wmi then “Laptop possibly affected by Recall Program” else “Not Affected by Recall”
(imported comment written by brolly3391)
On the Dell laptops on our account, the Latitude C610 and C640, WMI does not report the same model number that is printed on the sticker on the case of the battery. These are the original OEM batteries and not aftermarket.
Sticker on battery:
D/SN JP-07H508-48330-1CT-3MLT
D/PN 07H508 | C/O JP | Rev.A00
Printed on battery in white ink:
Type 75UYF
WMI:
DeviceID=62433Sony Corp.LIP8084DLP
As near as I can tell, the sticker indicates model 7H508, the white ink indicates 75UYF and WMI indicates model 62433 or P8084 or perhaps some other 5 character permutation of the string after the dot.
None of the character sequences that are reported in Win32_Battery seem to match anything that is printed on the sticker or anywhere on the battery case for these Dell models.
We have checked our batteries manually as well as using the relevance and we did not discover any that are on the list of effected batteries.
(imported comment written by StacyLee)
I was wondering how this is working out for others? I offered the Analysis out for our Console Operators to try out and I am having mixed reviews. One CO says she is seeing Desktop GX showing up as affected computers.
This is working well for us. At least initial impressions are good. It seems to be doing exactly as it states. Good work!
(imported comment written by wnolan91)
We have Dell GX Desktops in our environment but do not see them showing up as relevant. Only seeing Dell Laptops.
