Relevance to filter symlinks from directories(folders) not working?
(imported topic written by MarkA.Stevens)
Given the following:
  1. find /usr -type d -perm /002 -ls
65890 24 drwxrwxrwx 2 oracle dba 20480 Nov 11 07:02 /usr/lib/oracle/xe/app/oracle/admin/XE/adump
  1. ls -ld /usr/tmp
lrwxrwxrwx 1 root root 10 Aug 11 2010 /usr/tmp -> …/var/tmp
  1. ls -ld /var/tmp
drwxrwxrwt 4 root root 4096 Nov 22 10:41 /var/tmp
  1. ls -ld /usr/tmp/.oracle
drwxrwxrwt 2 root root 4096 Nov 11 07:03 /usr/tmp/.oracle
Then I sort of understand that I get the following (because symlinks can be pointed to directories):
Q: (descendant folders of folder “/usr”) whose (other mask of mode of it as string contains “w”)
A: /usr/lib/oracle/xe/app/oracle/admin/XE/adump
A: /usr/tmp
A: /usr/tmp/.oracle
T: 200654521
But I don’t understand why I don’t get “/usr/lib/oracle/xe/app/oracle/admin/XE/adump” for the following:
Q: (descendant folders of folder “/usr”) whose (other mask of mode of it as string contains “w” and not exists symlink of it as string)
T: 18535147
… Mark
(imported comment written by MarkA.Stevens)
So I’ve been working on this and have the following, which gives me the symlink’d directory.
Q: ((descendant folders of folder “/usr”) whose (other mask of mode of it as string contains “w”)) whose (exists values of symlink it as string)
A: /usr/tmp
T: 863863
But, the inversion (not …) doesn’t give me the other two, AND it takes FOREVER (okay 3.4 minutes) to run.
Q: ((descendant folders of folder “/usr”) whose (other mask of mode of it as string contains “w”)) whose (not (exists values of symlink it as string))
T: 209193072
I’m still confused.
… Mark
I’m not sure I really want to know the hours I spent on this. I finally stumbled upon the solution to find the writeable directories that are NOT symbolic links (symlinks):
Q: ((descendant folders of folder “/usr”) whose (other mask of mode of it as string contains “w”)) whose (exists symlink it equals false)
A: /usr/tmp/.oracle
T: 1417132
… Mark
