Can this relevenace statment be mix with shell/action script? I am not sure if that’s doable or not.
if exists process “httpd"
final_str=”“
http=ps -eaf|grep "sbin/httpd"|awk ' {print $8}'|grep -v grep|sort|uniq|xargs
if [ ! -z “$http” ]
then
for http_path in $http
do
vers=$http_path -version 2>&1|head -1|awk ' {print $3}'
final_str=”$http_path:$vers"","$final_str
done
echo $final_str|sed ‘s/,$//g’ > /tmp/bftask_httpd.log
fi
if exists process “java"
weblogic=ps -eaf|grep -iw java|grep -vi nolio|grep -i weblogic| grep -v grep|awk ' {print $8}'|sort|uniq|xargs
if [ ! -z “$weblogic” ]
then
for java_path in $weblogic
do
weblogic_jar=locate "/weblogic.jar"
if [ ! -z “$weblogic_jar” ]
then
weblogic_vers=$java_path -cp $weblogic_jar weblogic.version|sed '/^$/d'|head -1|awk ' {print $1$2"_"$3}'
final_str=”$java_path:$weblogic_vers"","$final_str
fi
vers=$java_path -version 2>&1 |head -1|awk ' {print $3}'|sed 's/"//g'
final_str="$java_path:$vers"","$final_str
done
echo $final_str|sed ‘s/,$//g’ > /tmp/bftask_java.log
fi
Assuming you wanted to run different shell scripts within an actionscript based on the existence of different processes, you could try something like the following (I’ve not tested this, but it should hopefully give you some insight into the approach):
if {exists process "httpd"}
delete __appendfile
delete runscript.sh
appendfile final_str=”“
appendfile http=ps -eaf|grep "sbin/httpd"|awk ' {print $8}'|grep -v grep|sort|uniq|xargs
appendfile if [ ! -z “$http” ]
appendfile then
appendfile for http_path in $http
appendfile do
appendfile vers=$http_path -version 2>&1|head -1|awk ' {print $3}'
appendfile final_str=”$http_path:$vers"","$final_str
appendfile done
appendfile echo $final_str|sed ‘s/,$//g’ > /tmp/bftask_httpd.log
appendfile fi
move __appendfile runscript.sh
wait chmod 555 runscript.sh
wait "{pathname of client folder of current site & "/runscript.sh"}"
endif
if {exists process "java"}
delete __appendfile
delete runscript.sh
appendfile weblogic=ps -eaf|grep -iw java|grep -vi nolio|grep -i weblogic| grep -v grep|awk ' {print $8}'|sort|uniq|xargs
appendfile if [ ! -z “$weblogic” ]
appendfile then
appendfile for java_path in $weblogic
appendfile do
appendfile weblogic_jar=locate "/weblogic.jar"
appendfile if [ ! -z “$weblogic_jar” ]
appendfile then
appendfile weblogic_vers=$java_path -cp $weblogic_jar weblogic.version|sed '/^$/d'|head -1|awk ' {print $1$2"_"$3}'
appendfile final_str=”$java_path:$weblogic_vers"","$final_str
appendfile fi
appendfile vers=$java_path -version 2>&1 |head -1|awk ' {print $3}'|sed 's/"//g'
appendfile final_str="$java_path:$vers"","$final_str
appendfile done
appendfile echo $final_str|sed ‘s/,$//g’ > /tmp/bftask_java.log
appendfile fi
endif
